2010 Harley-Davidson Dyna Wide Glide Review
Despite a slumping market, The Motor
Company introduced four new/revised models for 2010 this week.
Unveiled to the press in Denver, Colorado, we saw the return of the
Wide Glide to the Dyna family and a slick update to the Softail Fat Boy,
the Fat Boy Lo.
Also new is a tasty Road Glide Custom bagger and an even more
luxurious tourer, the Electra Glide Ultra Limited. We’ll discuss the
latter two in an upcoming article, concentrating here on the new Dyna
and Softail cruisers.
The Dyna series is the least expensive way to get into a Big Twin Harley,
starting at just $11,999 for the Super Glide model. Moving up in price
is the Street Bob and the Super Glide Custom, followed by this new Wide
Glide at a base price of $14,499. Dynas are easily recognizable by their
exposed dual rear shocks and underseat battery box.
The WG gets its name from its wide-placed 49mm fork laid out in a
generous chopper-style rake of 34 degrees. A consistent styling theme is
the contrast of black and chrome. The wide chrome triple-clamps are
accented with gloss-black handlebar clamps and risers, and this is
mimicked in the 40-spoke wheels with black rims and the black headlight
bucket highlighted by a chrome bezel. Similarly, the engine is
powdercoated black and accented by machined cylinder fins and
chrome-plated rocker and derby covers. Harley ups
the ante in the Dyna family with the new Wide Glide.
Also creating its own personality within the Dyna family is a black
battery box with a chrome “Wide Glide” logo, a mini sissy bar and a new
two-into-one-into-two “Tommy Gun” exhaust with slotted heat shields over
the rear header. The front of its 4.7-gallon fuel tank is kicked up
0.75 inch for a jauntier angle that contributes to its chopper profile
and the feeling of sitting “in” the bike.
Like many of Harley’s new models, there is a focus on reducing seat
heights to give riders a greater feeling of confidence. As such, both
ends of the suspension have been cut down to yield a seat just 25.5
inches from the ground. In comparison, the Dyna Super Glide’s seat is
placed at 26.3 inches.
The back end of the Wide Glide is interesting for two reasons. First,
there is no traditional stoplight, instead using the red-lens
turnsignal lamps as stoplights as first seen on the
Nightster. This innovative arrangement and chopped rear fender
provides an ultra-clean rear end. The surprising part of this story is
that European regulations do not allow such a system, so those on the
Continent have to suffer with a traditional taillamp as seen in our
action photography. For a change, North Americans get cooler stuff than
the Euros!
Wide Glide Ride
Straddling the new WG is effortless thanks to its low seat, but the
reach to the forward-set pegs is a stretch for those with short inseams.
The internally wired 1.25-inch handlebar is set on 4-inch risers for a
drag-style posture – fists punching the air – which rotates a rider’s
spine into a comfortable curve.
Low-speed maneuverability is typical of a raked-out front end with a
21-inch front wheel, feeling a bit awkward at parking-lot speeds because
of a floppy response at the bars. A light-effort clutch and throttle
help keep the 665-pound (wet) bike manageable.
Unlike the Softail line which is fitted with a counterbalanced
96-cubic-inch V-Twin, the Dyno line quells vibes via its rubber
mounting. At cruising speeds, the motor is very smooth, but at idle and
low revs, vibration is quite prevalent. As with all modern Harley
powerplants, throttle response is excellent, reacting smoothly and
precisely.
At Denver’s mile-high altitude, the impression of power from the TC96
is muted, and it is further diminished at the 9,000 feet we experienced
in the Rockies. This is a very nice motor, but some of its competitors
haves more grunt on tap. Peak torque arrives at 3,000 rpm, which
supplies very usable power at mid-range revs. The Wide
Glide's exhaust system limits cornering clearance on the right side.
Harley’s Big Twins are equipped with
the 6-speed Cruise Drive transmission, all of which are now fitted with
a helical-cut fifth gear to eliminate annoying gear whine. Gear
selection is positive if a bit clunky.
I wasn’t expecting stellar ride quality from the Wide Glide with its
slammed suspension, but I was pleasantly surprised by its behavior. In
most conditions it feels very composed, although it sometimes struggles
to feel balanced when trying to absorb repetitive bigger hits, partly
due to the wheels being set a lengthy 68.3 inches apart. And with the
suspension loaded in corners, the rear shocks reveal a deficiency in
rebound damping. I was impressed with the ground clearance available in
left-hand corners, but the amount of lean angle is more limited in
right-handers to protect the exhaust system.
Ergonomically, the WG is fairly benign. Its seat is firm but
supportive, and the tank-mounted speedometer is easy enough to read.
Self-canceling turnsignals are a convenient feature that should be
standard on many other bikes.
Small niggles include the air cleaner that intrudes on space for a
rider’s right knee and mirrors that fuzz at various rpm. A noticeable
amount of heat can be felt radiating from the engine’s rear header, and
the single-disc front brake can be diplomatically described as adequate.
The Wide
Glide’s attention-getting style can be had for less than $15,000.
Some may consider the above paragraph as damning with feint praise,
but these are minor issues which don’t seem to bother the Harley
faithful. For many, the gracefully sweeping lines of the attractive Wide
Glide will be enough to sway them into joining the family of Harley
faithful. There is no ignoring the many envious looks and comments the
WG regularly drew throughout our time aboard it. This won’t get it down a
canyon road as quick as some other cruisers, but it significantly adds
to the pride in ownership.
Like all things in life, the more you spend, the cooler it gets. The
$14,499 base price of the Wide Glide is for the handsome but subdued
Vivid Black version. An extra $375 will upgrade you to the slightly more
flamboyant but still stately Red Hot Sunglo. If you’re starving for
attention, you’ll want the Vivid Black with clear-coated flames graphic
for $15,194.
2010 Fat Boy Lo – Quick Ride
It didn’t take long after the Fat Boy’s 1990 introduction for it to
achieve an iconic status – perhaps you recall a robot from the future
that looked like an Austrian bodybuilder in a little film called Terminator
2. Its signature styling elements are a beefy FL-sourced fork,
solid disc wheels and the 5.0-gallon Fat Bob fuel tank. Harley calls
this newest iteration of the Fat Boy, the Lo, “a darker and lower
interpretation of the motorcycle that still defines the fat-custom
segment.”
The finishes from the Milwaukee company are above reproach, and this
is evident on the Fat Boy Lo. Against a backdrop of gloss black and
“Denim” black are lovely satin finishes on the engine and primary-drive
covers and, most noticeably, on the mufflers of the shotgun exhaust
pipes that glisten against the flat-black headers. It’s quite the
eye-popper.
Also visually arresting are the 17-inch “Bullet Hole” cast-aluminum
wheels with machined outer rims highlighting the black centers.
Continuing the fat theme are a wide 140mm front tire and a 200mm rear.
More fine detail work is found in the leather tank panel accented with
an H-D medallion and a satin-chrome instrument console.
The transition to Lo status is the result of the Softail rear
suspension being lowered 1.15 inches, plus a narrower seat, that results
in the lowest seat height of any Harley: 24.25 inches. A reshaped
handlebar completes the transformation.
The result is a very compact-feeling motorcycle for something that
weighs 731 pounds wet. “Half Moon” floorboards are are placed well
within reach and are very comfortable, but their shortcoming is that
they drag early and often when riding on twisty roads.
The Softail platform uses the TC96B motor, which means that it has a
counterbalancer to reduce vibration. This allows the engine to be
mounted rigidly in the chassis, enhancing chassis stiffness compared to
Harley’s rubber-mounted motors. The result is a better-handling
motorcycle, but the reduced ground clearance means that you can’t fully
exploit its potential.
My time aboard the Fat Boy Lo was too brief to provide a decent
evaluation, but in terms of visual appeal, this is one of Harley’s
finest work. The glossy Vivid Black version retails for $16,299, while
the matte-finished Black Denim option has an MSRP of $16,674.
H-D CVO Model Line-Up Preview
Harley-Davidson Street Glide Review
Harley-Davidson Touring Models Review
Harley-Davidson Models
All
Things Harley-Davidson
the Fat Boy Lo.
The 2010 Dyna Wide Glide strikes a pose. |
the Euros!
Wide Glide Ride
Black and chrome and flames are a powerful cruiser combination. |
precisely.
The Wide
for $15,194.
segment.”
The Fat Boy Lo's contrasting finishes are a visual treat. |
The Softail chassis underpins the chunky Fat Boy. |
This shot demonstrates how the Fat Boy comes by its name honestly. |
eye-popper.
All
» 2010 Harley-Davidson Sportster 883 Low Review
» 2010 Harley-Davidson Sportster Forty-Eight Review
» 2009 Harley-Davidson Iron 883 Review
» 2007 Harley-Davidson Night Rod Special Review
» 2009 Harley-Davidson VRSCF V-Rod Muscle Review
